[SOLVED] Ubidots to Blynk
I’m looking for a help with my first project.
I have a device sending data to Ubidots and from there I’m trying to send data to Blynk app through a webhook triggered by an event (I was originaly sending data directly to Blynk but it was somehow unreliable). All of this works except Blynk never receives the data. I tried PUT and GET requests but it simply wont work.
Am I doing anything wrong?
Here’s blynk documentation: https://blynkapi.docs.apiary.io/#
Hello, stjirka.
I’ve already replicated what you’re trying to do and it works (I’m using the value of a switch widget).
Please try this:
  • Make sure that the blynk token you’re using correspond to the current project.
  • Make sure you’re using the right pin at the end of the webhook’s URL.
  • Remove quotation marks from your webhook’s body.
Let me know if this works.
Daniela.
Thank you Daniela,
I’have now managed to make it work. I had to ping blynk-cloud.com and replace it in the URL with its IP address. The quotation marks did’n seem to make any difference. But I’ll remove them just to keep it clean.
