UbidotsESP8266.h, get value bad request
I have a problem with getValue function. the first run return HTTP 200 but then always 400(bad request).
I’m using arduino uno and connect to ESP8266 12F via softwareSerial pin 2,3. Using the sample code but got this problem.
Serial debug
Response of ESP8266:
AT+CIPSEND
OK
HTTP/1.1 200 OK
Server: nginx
Date: Mon, 03 Oct 2016 08:59:06 GMT
Transfer-Encoding: chunked
Connection: close
Vary: Accept-Encoding
Vary: Accept
148
{“count”: 15, “next”: “http://things.ubidots.com/api/v1.6/variables/57e8de5b76254216a82a995e/values?page=2&page_size=1”, “previous”: null, “results”: [{“url”: “http://things.ubidots.com/api/v1.6/values/57f2041f76254243baa24719”, “value”: 1.0, “timestamp”: 1475478559115, “context”: {}, “created_at”: “2016-10-03T07:09:19.115”}]}
0
HTTP/1.1 400 Bad Request
Server: nginx
Date: Mon, 03 Oct 2016 08:59:17 GMT
Content-Type: text/html
Content-Length: 166
Connection: close
400 Bad Request
400 Bad Request
nginx
clearin data
Server: nginx
Date: Mon, 03 Oct 2016 08:59:20 GMT
Content-Length: 166
Connection: close
400 Bad Request
400 Bad Request
nginx
Can you help me?
version of ESP from AT+GMR
AT version:1.3.0.0(Jul 14 2016 18:54:01)
SDK version:2.0.0(656edbf)
Arduino IDE version : 1.6.9
Thank you.
@kutarte Then, it works only in the first time?
Metavix
@Metavix, Yes. Works only in the first time.
i try to change the button state in my dashboard but always bad request.
What should i do?
Best Regards,
Kutarte
@kutarte Paste here your code please. I will help you with that
Metavix
Hi @Metavix,
#include <UbidotsESP8266.h>
#include <SoftwareSerial.h>
#define SSID "TCS 1"
#define PASS "P@ssvv0rd"
#define TOKEN "B80RLEzYYE8jzRpECKjqTf9l------"
#define ID "57e8de5b76254216a8------"
  pinMode(4,OUTPUT);
  digitalWrite(4,HIGH);
  float value;
  value = client.getValue(ID);
  Serial.print("value : ");
  Serial.println(value);
  if(value > 0){
    digitalWrite(4,LOW);
  else digitalWrite(4,HIGH);
Best Regards,
Kutarte
Hi @Metavix,
Should I replace the ESP8266 firmware with the old version?
I had already upgraded its firmware to the latest version
Do you have any recommendations for the firmware version that work properly?
Best Regards,
Kutarte
@kutarte yeah it a good idea to try, i have a ESP with the old version and it works fine
By the way is much better to find the problem with the new firmware and try to solve it
Metavix
@Metavix, so what is your firmware version?
I don’t know how to find the problem now.
Do you have any library with MQTT protocol for ubidots? but using ESP8266 as a bridge/shield for arduino uno R3 via serial.
Best Regards,
Kutarte
I strongly recommend MQTT and not GET. You can use the PubSubClient library, works like a charm with Ubidots.
#include <PubSubClient.h>
#include <ESP8266WiFi.h>
#include <ESP8266WiFiMulti.h>
#define WIFISSID "IOT"
#define PASSWORD "SM1OT2016"
#define TOPIC1 "/v1.6/devices/motor/relay/lv"
#define TOPIC2 "/v1.6/devices/motor/temp"
#define TOKEN "xxxx"
#define PIN 12
int a;
const int B = 4275;                 // B value of the thermistor
const int R0 = 100000;            // R0 = 100k
const int pinTempSensor = A0;     // Grove - Temperature Sensor connect to A5
char payload[100];
ESP8266WiFiMulti WiFiMulti;
WiFiClient c;
PubSubClient client(c);
    char p[length + 1];
    memcpy(p, payload, length);
    p[length] = NULL;
    String message(p);
    if (message == "0") {
      digitalWrite(PIN, LOW);
      digitalWrite(PIN, HIGH);
    Serial.println(topic);
void reconnect() {
  while (!client.connected()) {
    // Attempt to connect
    if (client.connect("linkit-one", TOKEN,"")) {
      Serial.println("connected");
      client.subscribe(TOPIC1);
      Serial.print("failed, rc=");
      Serial.print(client.state());
    pinMode(PIN, OUTPUT);
    delay(10);
    // We start by connecting to a WiFi network
    WiFiMulti.addAP(WIFISSID, PASSWORD);
    Serial.print("Wait for WiFi... ");
    while(WiFiMulti.run() != WL_CONNECTED) {
        Serial.print(".");
        delay(500);
    Serial.println("");
    client.setCallback(callback);
    if (!client.connected()) {
      reconnect();
    a = analogRead(pinTempSensor );
    float R = 1023.0/((float)a)-1.0;
    R = 100000.0*R;
    float temperature = 1.0/(log(R/100000.0)/B+1/298.15)-273.15;//convert to temperature via datasheet ;
    sprintf(payload,"%s%d.%02d%s", "{\"value\":", (int)temperature, (int)(temperature*100)%100,"}");
    Serial.println(payload);
    client.publish(TOPIC2, payload);
    memset(payload, 0, sizeof(payload));
Hi @hackmed,
Thank you for your recommendation
is that program for ESP8266 standalone or as a additional modul for arduino uno?
Best Regards,
Kutarte
This one was tested with a NodeMCU board (standalone ESP), good luck!
I See @hackmed.
For some reason i need the ESP8266 as a bridge. Thank you by the way, I’ll try it after my problem solve (As a bridge).
Best Regards,
Kutarte
@kutarte i used this one http://www.electrodragon.com/w/ESP8266_AT_Commands, the clasic version
Metavix
Thank you @Metavix, I will try that version. But I still hope u can solve the problem on new version of firmware ESP8266.
I used this version http://bbs.espressif.com/viewtopic.php?f=46&t=2451,
and flashing with this parameter
yeah @kutarte, i am testing that version too, in this moment i find that the firmware of espressif has a lot of noise with SoftwareSerial library of Arduino. Now im using other libraries of Serial to reduce that noise. I think that today i will post the new version of the library, that will work.
Metavix
Thank you so much @Metavix, I’m waiting for that fix version of library.
Best Regards,
Kutarte
@Metavix, I’ve try the old version that you gave to me
AT version:0.40.0.0(Aug  8 2015 14:45:58)
SDK version:1.3.0
Ai-Thinker Technology Co.,Ltd.
Build:1.3.0.2 Sep 11 2015 11:48:04
But I still have the same problem. Are you using ESP-12 like me or the other type of ESP?
Best Regards,
Kutarte
@kutarte im using the same of you, could you try to put an pull down resistor, it may reduce the noise.
In this moment im trying with AltSoftwareSerial lib, with the example of 2 serial ports of that library.
Metavix
Where I should put the pull down? rx & tx?
Thank you @Metavix
Best Regards,
Kutarte
RX of the Arduino. You might use a example from the web.
Metavix
