Ubidots Community
Using Mapbox in HTML Canvas
Greetings.
I’m currently in the process of creating a map widget using HTML canvas and Mapbox.
I’ve managed to follow the examples on Mapbox homepage and made custom maps using their Mapbox GL JS (Https://docs.mapbox.com/mapbox-gl-js/example/video-on-a-map/). It seems to work just fine when I run it on JSFiddle but I can’t figure out how to make it work on ubidots dashboard.
I read an example on ubidots resource page but it didn’t make much sense as it had no comments on the code. Is there an example with comments that I can follow?
Hi @jin167,
I hope all is well.
Please refer to the following article, example 4, where you can learn how to create a Mapbox map using the HTML Canvas widget.
