Hi, I wanna make a IoT project, but I noticed there is two methods to send variables by mqtt, What is the difference ?
The first one : use too many sprintf + client.publish functions:
 * This Example sends harcoded data to Ubidots and serves as example for users that have devices
 * based on ESP8266 chips
 * This example is given AS IT IS without any warranty
 * Made by Jose García @https://github.com/jotathebest/ ,
 * adapted from the original WiFiClient ESP8266 example
 * Include Libraries
#include <PubSubClient.h>
#include <ESP8266WiFi.h>
#include <ESP8266WiFiMulti.h>
#include <stdio.h>
 * Define Constants
#define WIFISSID "...." // Put your WifiSSID here
#define PASSWORD "...." // Put your wifi password here
#define TOKEN "...." // Put your Ubidots' TOKEN
#define DEVICE_LABEL "weather-station" // Put the device label
#define VARIABLE_LABEL_1 "temperature" // Put the variable label
#define VARIABLE_LABEL_2 "humidity" // Put the variable label
#define MQTT_CLIENT_NAME "...." // MQTT client Name, put a Random ASCII
char mqttBroker[] = "industrial.api.ubidots.com";
char payload[700];
char topic[150];
char str_val_1[6];
char str_val_2[6];
 * Initializate constructors for objects
ESP8266WiFiMulti WiFiMulti;
WiFiClient ubidots;
PubSubClient client(ubidots);
 * Auxiliar Functions
  Serial.print(topic);
  Serial.print("] ");
  for (int i=0;i<length;i++) {
void reconnect() {
  while (!client.connected()) {
  // Attempt to connect
  if (client.connect(MQTT_CLIENT_NAME, TOKEN,"")) {
    Serial.println("connected");
    Serial.print("failed, rc=");
    Serial.print(client.state());
 * Main Functions
  WiFiMulti.addAP(WIFISSID, PASSWORD);
  Serial.print("Wait for WiFi... ");
  while(WiFiMulti.run() != WL_CONNECTED) {
    Serial.print(".");
    delay(500);
  Serial.println("");
  client.setCallback(callback);
  if (!client.connected()) {
    reconnect();
  // Values to send
  float temperature = random(0, 50);
  float humidity = random(0, 50);
  /* 4 is mininum width, 2 is precision; float value is copied onto str_temp*/
  dtostrf(temperature, 4, 2, str_val_1);
  dtostrf(humidity, 4, 2, str_val_2);
  sprintf(topic, "%s", ""); // Cleans the topic content
  sprintf(payload, "%s", ""); // Cleans the payload content
  sprintf(payload, "{\"%s\":", VARIABLE_LABEL_1); // Adds the variable label
  sprintf(payload, "%s {\"value\": %s}", payload, str_val_1); // Adds the value
  sprintf(payload, "%s, \"%s\":", payload, VARIABLE_LABEL_2); // Adds the variable label
  sprintf(payload, "%s {\"value\": %s}", payload, str_val_2); // Adds the value
  sprintf(payload, "%s}", payload); // Closes the dictionary brackets
  Serial.println(payload);
The second one use only few functions “add and ubidotsPublish” to indicate variables and device:
 * This example works for both Industrial and STEM users.
 * If you are using the old educational platform,
 * please consider to migrate your account to a STEM plan
 * Developed by Jose Garcia, https://github.com/jotathebest/
 * Include Libraries
#include "UbidotsESPMQTT.h"
 * Define Constants
#define TOKEN "....."     // Your Ubidots TOKEN
#define WIFINAME "....."  // Your SSID
#define WIFIPASS "....."  // Your Wifi Pass
  Serial.print("] ");
 * Main Functions
  client.setDebug(true);  // Pass a true or false bool value to activate debug messages
  client.begin(callback);
    client.reconnect();
  // Values to send
  // Publish values to 2 different data sources
  client.add("VARIABLE_LABEL_1", temperature);  // Insert your variable Labels and the value to be sent**
  client.add("VARIABLE_LABEL_2", humidity);
  client.ubidotsPublish("DEVICE_LABEL");**
