What is the minimum heartbeat i can set for sensor reading?
What is the minimum heartbeat i can set for sensor reading? 1 minute?
Hi @alvinphee,
Thank you for sharing your question with the community. All the Ubidots paid lincenses can ingest 4 requests per second per Token, each one can have a maximum of 10,000 bytes. While Ubidots STEM accounts have an API rate limit of 1 request per second per token across all devices. This is valid in all Ubidots supported protocols – HTTP, MQTT, and TCP & UDP. Please refer to the following article for more information.
