Hi,Andy
So You already fixed all of this? Or still in progress?
Hi
No it is not fixed. There is still a bug in the system which occasionally reports that you used hundreds of thousands of Dots Out.
I consume less than 40,000 a day but some days - even some days when I haven’t used Ubidots - it suggests I’ve used over ten times that.
Andy
Hi @andy.krafft,
I hope you are doing well.
I want to clarify for the sake of informing the community that there is not an identified issue in the counting of dots out or in. I personally make sure that both dots in and out are being counted correctly based on the account consumption. Now, we are investigating the particular case of your account, to identify the reason for the number of dots out as you express you are not consuming the amount showed in your account usage. We hope to clarify this case sooner and if there is anything I can do in the meantime please let me know.
-Isabel
Hi Isabel
Thanks for looking into this.
For the sake of clarity, I think it worth pointing out that it is not just the particular case of my account - I can find at least six posts on this forum stretching back to June that have experienced the same problem.
So it is not just confined to me.
Andy
Hi Isabel
Thank you for increasing my dots again. In case it helps your investigation, I have just had a notification: “You’ve retrieved 701772/700000 dots today”
I have not used the system any more than any other day.
Andy
Good day @andy.krafft,
I hope this note finds you well.
After sharing your case with our team and understating how frustrating could be to no be able to access your account data for reaching the dots limit, we decided to explore how to make the consumption visible and predictable to our users, until then, you don’t need to worry to reach out the limits again.
-Isabel
Hi Isabel
Although it doesn’t fix the issue I think this is a very sensible idea - thanks.
Andy
Hi Isabel
I installed Network Sniffer. For some days there’s been no traffic unless I press refresh.
But suddenly I am getting traffic when I am away from my desk. It is happening quite frequently - many times a minute.
They all look similar to this and are all xmlhttprequest types:
Request Headers
URL: https://stem.ubidots.com/notifications/?EIO=3&transport=polling&t=NUCmDLq
Sec-Fetch-Site : same-origin
Sec-Fetch-Mode : cors
Sec-Fetch-Dest : empty
Response Headers
Server : nginx
Date : Wed, 10 Feb 2021 16:23:08 GMT
Content-Type : text/plain; charset=UTF-8
Content-Length : 103
Could this be causing the excessive Dots Out?
Andy
Hi @andy.krafft,
This should be happening only if you have the Real-Time option available or if you are making GET requests via API. Please let me know if none of the below is the case to further investigate based on your findings.
-Isabel
Hi Isabel
I do not, and never have had, the Real-Time option turned on.
I do not use, and never have used, the API.
Andy
No, it doesn’t. The endpoint that you are referring to in your post is related to the notifications of your account, not with the dots out count.
Hi
Thanks for the clarification.
So is it just https://stem.ubidots.com/api/v1.6/widgets/xxxxxxxxx and https://stem.ubidots.com/api/v1.6/variables/xxxxxxxxxxx calls that will generate Dots Out?
Andy
Nudge
Hi
FYI it’s maxed out again today.
I’ve done a few refreshes this morning but less than yesterday (which your system recorded as 74,399)
So 700,000 dots out burned up.
Andy
Hi
It’s done it again. I did a few refreshes 7 hours ago (so 10k - 20k dots). Tried again just now and 700,000 dots exceeded.
This is very frustrating.
Andy
Hi Andy,
For the second time, we put a log to detect your account consumption and found that you are indeed making those dots out consumption through Dashboards. As you can see in the following image, all consumption comes from the same dashboard via Real-Time, which updates the data and recharges successively. Please rectify that you don’t have the Real-time enable and the amount of data the widgets are asking for is from a short period to ensure you don’t exceed the limits again.
Additionally, as I mentioned in a previous note, the product team has decided to partially remove some consumption from the dots out daily count. I said partially, as Dots out currently involves consumption from Dashboards, Data exports, Reports and API (retrieving data from 3rd platforms or your devices), so for the sake of not blocking you and your projects, Dashboards, Data exports, and Reports will no longer generate Dots out consumption. This implementation is in progress so it will take additional days to reflect this change in the account. Please note that retrieving data through the API will still generate Dots out consumption.
-Isabel
Hi Isabel
Thanks for the screenshot.
I can categorically confirm that real-time is not enabled. At least not by me. I have never had it turned on.
You will also know from earlier posts that I have had Network Sniffer running since early February. It did not detect the API calls that your screenshot shows. So the calls were not generated by me.
I assume the screenshot shows the result of Dots Out from a dashboard (as opposed to the Devices overview page or an individual device page).
At 2021-02-19 21:31 (the top line of the image) my dashboard would have pulled 6 data sources. 4 were single data points and 2 were a date range starting from 2021-02-09 22:04. This equates to 479 values for the two date ranges and 4 values for the other 4. I have confirmed this by directly pulling the JSON using curl.
Your image seems to have a number of values (and, weirdly, dates out of order). I am not sure how to correlate the dots_out value as shown in the image with the JSON. Even assuming somehow I had real-time tuned on it does not seem to match up.
Values of 2084, 795, 171, 501, etc bear no relationship to reality. Where do these come from?
Andy
Hi
On 25/2 (reported as 26/2) I had a Dots Out (API) of 11,810.
This is the first time I have ever seen this. I don’t use the API so how can this happen?
Regards
Andy
Thank you for your report and detail explanation of your dots out consumption. After a detailed review of the dots that were being generated by your Dashboard, we were able to detect that there is an issue counting dots out in the Dashboard side when the real-time option of the Dashboard is paused. We are already working on the solution and we are sorry for the inconvenience this may cause. I will let you know as soon as I have an update.
-Isabel
Hi Isabel
That is great news. I am glad that you have found the bug as it has proven to be a frustrating experience and one that has clearly affected many users.
Andy
