Hi
FYI it’s maxed out again today.
I’ve done a few refreshes this morning but less than yesterday (which your system recorded as 74,399)
So 700,000 dots out burned up.
Andy
Hi
Andy
Hi
It’s done it again. I did a few refreshes 7 hours ago (so 10k - 20k dots). Tried again just now and 700,000 dots exceeded.
This is very frustrating.
Andy
Hi Andy,
I hope this note finds you well.
For the second time, we put a log to detect your account consumption and found that you are indeed making those dots out consumption through Dashboards. As you can see in the following image, all consumption comes from the same dashboard via Real-Time, which updates the data and recharges successively. Please rectify that you don’t have the Real-time enable and the amount of data the widgets are asking for is from a short period to ensure you don’t exceed the limits again.
Additionally, as I mentioned in a previous note, the product team has decided to partially remove some consumption from the dots out daily count. I said partially, as Dots out currently involves consumption from Dashboards, Data exports, Reports and API (retrieving data from 3rd platforms or your devices), so for the sake of not blocking you and your projects, Dashboards, Data exports, and Reports will no longer generate Dots out consumption. This implementation is in progress so it will take additional days to reflect this change in the account. Please note that retrieving data through the API will still generate Dots out consumption.
Hi Isabel
Thanks for the screenshot.
I can categorically confirm that real-time is not enabled. At least not by me. I have never had it turned on.
You will also know from earlier posts that I have had Network Sniffer running since early February. It did not detect the API calls that your screenshot shows. So the calls were not generated by me.
I assume the screenshot shows the result of Dots Out from a dashboard (as opposed to the Devices overview page or an individual device page).
At 2021-02-19 21:31 (the top line of the image) my dashboard would have pulled 6 data sources. 4 were single data points and 2 were a date range starting from 2021-02-09 22:04. This equates to 479 values for the two date ranges and 4 values for the other 4. I have confirmed this by directly pulling the JSON using curl.
Your image seems to have a number of values (and, weirdly, dates out of order). I am not sure how to correlate the dots_out value as shown in the image with the JSON. Even assuming somehow I had real-time tuned on it does not seem to match up.
Values of 2084, 795, 171, 501, etc bear no relationship to reality. Where do these come from?
Andy
Hi
On 25/2 (reported as 26/2) I had a Dots Out (API) of 11,810.
This is the first time I have ever seen this. I don’t use the API so how can this happen?
Andy
Good day @andy.krafft,
I hope you are doing well.
Thank you for your report and detail explanation of your dots out consumption. After a detailed review of the dots that were being generated by your Dashboard, we were able to detect that there is an issue counting dots out in the Dashboard side when the real-time option of the Dashboard is paused. We are already working on the solution and we are sorry for the inconvenience this may cause. I will let you know as soon as I have an update.
Hi Isabel
That is great news. I am glad that you have found the bug as it has proven to be a frustrating experience and one that has clearly affected many users.
Andy
Hi Isabel
In case it helps your analysis, I ran a test over the last few days.
My device - an iSpindel - generates 1776 data points per day (6 metrics every 00:04:51). There are also two calculated (synthetic) data points. This should be another 592 data points.
I set up a test whereby I set the time period of my dashboard to be a fixed 24 hours (midnight to midnight) on a date in the past. I have 5 widgets: 4 are single data point and one uses a 30 minute average of two data points. Thus the 5 calls (https://stem.ubidots.com/api/v1.6/widgets/5f183xxxxxxx/data?tz=…) generate 100 data points exactly: 4 + 48 * 2. I confirmed this with a manual curl script.
Question 1: The Dots In tallies (1776) with your usage report. However the “Dots Out (Synthetic variables)” is showing 988. Why not 592?
Question 2: On two separate days I performed a single refresh of the dashboard. On each occasion the Dots Out is given as 596. Why has it overcounted by 496?
Andy
Hi Isabel
Being pedantic in case it is significant, I don’t know how you define “paused” but I have never used the real time facility.
“Paused” suggests that it has been used and then stopped temporarily. This is not the case.
Andy
Hi @andy.krafft,
Please find below the answer to the questions of your initial reply.
The dots out generate by synthetic variables vary depending on the expression, as in some cases it is necessary to request more than one dot from the raw variable to calculate the expression, additionally each time a new data arrives to the raw variable, the synthetic variable computes a new value. It is also important to bear in mind that although this consumption is shown in the usage of the account, it is not taken into account in the total count of dots out included in the accounts.
Now, the issue in counting the dots out on the dashboard side happens when there is a widget that has an aggregation method configured and the real-time of the dashboard is paused if the dashboard is still open when new data arrives to the variable, dots out are generated even though there is not any actualization needed. The team is already in the process of solving this problem and we apologize for any frustration or confusion. I hope to have an update by the end of the week.
Hi Isabel
Thanks for the Q1 answer which makes sense.
I’ve re-read your answer to Q2 a few times. If I understand you correctly you are saying that if, say, an hour average is calculated on the hour - but that you refresh the dashboard between this - it erroneously generates Dots Out? That may indeed be a bug but it doesn’t explain a lot of my observations. Check back through this thread to see what I mean.
Andy
Hi @andy.krafft
Let me explained in detail the issue that was occurring in the consumption of dots out on the Dashboard side. Currently, each Ubidots Dashboard has 3 buttons on the upper left side.
One of those buttons is a play and pause button that enables the real-time of the dashboard which means updating the data of the widgets based on the new data that is being received in the variables. For example, if you have the dashboard open, with the real-time enable the widget should update its values to show the new ones, which generate dots out consumption.
Now, the issue was related when the real-time option was paused and there was one widget or more with an aggregation method configured.
In this scenario, the Dashboard should not generate dots out as the real-time option is disabled which implies that the dashboard will not update based on new data. unfortunately, consumptions were being generated in these widgets when new data was received in the variables, even though the widget did not update its value on the dashboard side. The team has already deployed a solution for this issue and we are currently monitoring its correct operation. We apologize for any confusion and inconvenience.
Please let me know if you have further questions.
Hi Isabel
Great news and let’s hope this fixes some of the excessive Dots Out I and others have been experiencing.
Andy
Hi Isabel
I don’t see how the bug you have just described would cause this.
I did a single refresh and then closed the Chrome tab so the dashboard was not open.
Andy
Hi Isabel
FYI, my Dots Out since the 9th has been much more as expected.
Looking good.
Andy
Hi
Has this bug reappeared?
“You’ve reached your daily quota of data extraction. You’ve retrieved 706442/700000”
My usage has suddenly leapt massively in the last week or two despite no change in behaviour.
Andy
