Ubidots
Cold-chain monitoring software development
Custom cold-chain monitoring software, from walk-in to truck
You own the application; we keep everything underneath it running. We build the temperature monitoring, excursion alerts and records your teams rely on — for walk-ins, cold rooms, pharmacy fridges and reefers — on a platform already in production.
Why it is faster
A development shop starts with an empty repository. We start with a platform in production.
Most of a cold-chain application has nothing to do with temperature. It is ingestion, storage, logins, alerting and the records your auditors ask for — and whoever builds it has to maintain it forever.
Building from scratch You pay for all of it
Before anyone builds the excursion report you asked for, a team builds — and then maintains — the whole stack underneath it.
Building on Ubidots You pay for the top
The work begins at your data model and your interface, because everything below that line already exists and is under support.
Reporting and alerting already running
Authentication, users and roles already running
Time-series storage already running
Device ingestion and protocols already running
Security, uptime and upgrades our job
What we build for the cold chain
Custom software for everything that has to stay cold
Every project starts from a list — a handful of screens, a calculation, an integration. These are the ones cold-chain operators bring us most.
Walk-in cooler and freezer monitoring
Temperature and door status for every walk-in and reach-in across your stores and kitchens, with a clear status per location so nobody has to open a dashboard to know where the problem is.
  • Status rollup per location
  • Door-left-open alerts
  • Readings log per unit
Cold storage and warehouse monitoring
Temperature and humidity per zone in cold rooms and distribution warehouses, with the history to show what changed before an excursion and how long it lasted.
  • Zone maps with live readings
  • Excursion duration and peaks
  • Scheduled reports per site
Reefer and in-transit monitoring
Refrigerated trailers and containers report temperature and location over cellular, so dispatch sees an excursion while the load is still on the road, not after delivery.
  • Temperature with location
  • Alerts while in transit
  • Trip records per load
Pharmacy and vaccine storage
Fridges and freezers holding medicines and vaccines, with min/max tracking, excursion alerts and acknowledgements kept as records your team can use in audits.
  • Min/max tracking per unit
  • Excursion alerts with acknowledgement
  • Exportable temperature records
Mobile apps for store and site managers
Branded iOS and Android apps for the people who act on an alert — built as a customisation of an existing app, so login, navigation and push alerts are reused, not rebuilt.
  • Green, yellow and red status per site
  • Push alerts and acknowledgements
  • Thresholds set from the app
Industrial AI across your cold chain
Agents that keep an eye on every unit, summarise the night's excursions and answer questions like “which stores had a cooler out of range this week?” through Channels like WhatsApp.
  • Morning excursion summaries
  • Questions answered from live data
  • Actions through Connectors
Connectivity
Connect every cooler, room and truck
A cold chain runs through kitchens, warehouses and the back of a truck, and each needs a different link. We work with what your sites already have, or specify what they need. Hardware is specified, not supplied.
WIRELESS
Sensors in stores and warehouses
Battery-powered temperature, humidity and door sensors over LoRaWAN, inside walk-ins and cold rooms where cables can't go.
CELLULAR
Trucks, reefers and remote sites
LTE-M, NB-IoT or 4G devices that report temperature and location from the road or from sites without a network.
CONTROLLERS
Refrigeration equipment
Refrigeration controllers already on site report through an edge gateway, over Modbus or MQTT.
SYSTEMS
Your other systems
ERP, WMS, transport or quality software, connected by API or webhook and scoped as its own work package.
Connectivity:LoRaWANLTE-M / NB-IoTMQTTHTTP / RESTModbus via gatewayWebhooks
You own it. We run it.
Completely custom, without a maintenance backlog
A platform you build yourself is worth the most on the day it ships. After that, someone owns its uptime, its security patches and every dependency in it — permanently.
Here, everything above the line is yours: the data model, the screens, the brand. Everything below it is ours to run, under support, and it keeps improving underneath you without landing on your roadmap.
Where a custom application is the deliverable, the code is written as work for hire. You own the repository and have access to it throughout the build, not at the end.
How an engagement runs
Five stages, and the number gets tighter at every one
Nobody can price a conversation accurately. So we tell you how wide the estimate is at each stage, and narrow it by doing work rather than by guessing harder.
Qualification
A short call to capture scope and sizing, and to put an indicative range on the work.
±100%
Specification
Your requirements document — or a fixed-fee, timeboxed discovery that produces one.
±50%
Estimation
Every requirement mapped to a work package, each one sized. A range we can defend line by line.
±50%
Prototype
Something you can use on the real platform before the build is committed. Then re-estimated.
±25%
Build
Agreed scope, stated exclusions, delivered in reviewable increments with monthly effort reporting.
Fixed scope
Discovery, when you need one, is a fixed fee credited in full against the project that follows. Build phases run under a not-to-exceed ceiling you set: work stops for your approval at the ceiling rather than running past it.
On the role of AI
AI compresses the build. Engineers still own the quality.
It would be easy to overclaim here, so plainly: AI-assisted development compresses the build step, which is the part that used to dominate a quote.
It does not compress the senior specification in front of it, or the code review and QA after it. Those are why the result is maintainable, they are done by engineers, and they sit inside the same rate.
Spec
Build — AI-compressed
Review
QA
15%45%15%25%
Typical effort split of a custom build. The cyan block is where the time goes away; the rest is the human quality floor.
In the field
What this looks like in practice
Two engagements by our team: a cold-chain app for a restaurant-services operator, and a connected product for an industrial distributor.
Restaurant services · walk-in coolers
Walk-in cooler monitoring a manager can read mid-shift
A restaurant-services operator on the Ubidots platform since 2022 needed a second product line that looked nothing like a dashboard. The constraint was simple: an owner with thirty locations should see in seconds which kitchen has a problem.
1,000+devices on the platform
2022on Ubidots since
The app: location cards with a green, yellow and red rollup, sensor detail with a 24-hour chart and threshold lines, a readings log, CSV export and per-sensor settings that write thresholds back to the platform's events engine. It's built as a customisation of the existing Ubidots mobile app, so login, navigation and push alerts are reused.
Specified, estimated and quoted for iOS and Android, alongside a sibling app for the same operator.
Industrial distributor · connected product
A gas-detection distributor that needed connectivity of its own
Their detectors competed well on sensing and badly on connectivity. After winning a tender, they needed a connected layer in time to deliver it.
5gases decoded per frame
20–30 spublish interval
An Android app turns the phone into the gateway: it pairs over Bluetooth, decodes the manufacturer's binary frame, tracks location and publishes to a central console with a live map and alarm panel. The client owns the source.
Proposals signed August 2026 · dedicated team, sprint demos as acceptance. The app relays detector data; it is not a safety device and does not replace the detector or its alarms.
FAQ
Questions cold-chain teams ask first
What is cold-chain monitoring?
Cold-chain monitoring is continuously measuring the temperature of products that must stay cold — and often humidity, door status and location — in walk-ins, cold rooms, pharmacy fridges and reefers, and alerting someone the moment a reading drifts out of range. Custom software fits it to your sites, your products and the records your team keeps.
Why is building on Ubidots faster than building from scratch?
Because the work starts at your data model and your interface, not at an empty repository. Ingestion, time-series storage, authentication, roles, alerting and reporting already exist and are in production. AI-assisted development then compresses the build step itself, while specification, code review and QA stay with senior engineers.
Does it make us FDA or HACCP compliant?
No software does that on its own. The platform keeps timestamped temperature records, excursion alerts and who acknowledged them — records your team can use in HACCP plans and audits. Whether you're compliant depends on your processes and validation, not on the software.
What happens when a sensor or gateway stops reporting?
You find out. Inactivity rules flag any device that stops sending data, so a dead battery or a lost connection shows up as an alert instead of a silent gap in the record. Alerts go out by SMS, email, voice call, Telegram, WhatsApp or webhook, with escalation if nobody acknowledges them.
Which connectivity works for coolers, warehouses and trucks?
Battery-powered wireless sensors over LoRaWAN inside stores and warehouses, cellular (LTE-M, NB-IoT, 4G) for trucks, reefers and sites without a network, or an edge gateway reading refrigeration controllers over Modbus or MQTT. We specify the hardware for each site; we don't supply it.
Who maintains the software after it is delivered?
The infrastructure underneath your application — ingestion, storage, orchestration, security, availability and upgrades — is run and maintained by Ubidots under your platform subscription. You own the application layer. Changes to it after delivery are scoped as new work, the same way the original build was.
Do we own the code?
On engagements where a custom application is the deliverable, the code is written as work for hire: you own the repository and the source, with access throughout the build rather than at the end. The platform underneath stays Ubidots'.
How much does custom cold-chain monitoring software cost?
It depends on scope, and an honest first answer is a range rather than a number. We give that range on the first call, then narrow it at each stage: specification, work-package estimate, and a prototype you can use before the full build is committed. Discovery, when you need one, is a fixed fee credited against the project.
Do we need a Ubidots subscription?
Yes. The application runs on the Ubidots platform, and the subscription is scoped and quoted separately from the development work. Development is not part of a subscription, and a subscription is not part of a development engagement.
Start with one message
Tell us what needs to stay cold, and where
Tell us what you need. We'll get back to you to work out whether there's a project here, and put a range on it that's honest about how wide it still is.
Get in Touch
Get in Touch
Get the best of our product and team
Main IoT verticals (select up to 3)
