Ubidots
Predictive maintenance software development
Custom predictive maintenance software, from signal to work order
You own the application; we keep everything underneath it running. We build the condition monitoring, alerts and maintenance workflows your teams act on — for motors, pumps, fans and compressors — on a platform already in production.
Why it is faster
A development shop starts with an empty repository. We start with a platform in production.
Most of a predictive maintenance application has nothing to do with prediction. It is ingestion, storage, logins and alerting — and whoever builds it has to maintain it forever.
Building from scratch You pay for all of it
Before anyone builds the asset health screen you asked for, a team builds — and then maintains — the whole stack underneath it.
Building on Ubidots You pay for the top
The work begins at your data model and your interface, because everything below that line already exists and is under support.
Reporting and alerting already running
Authentication, users and roles already running
Time-series storage already running
Device ingestion and protocols already running
Security, uptime and upgrades our job
What we build for maintenance
Custom software for the machines you can't afford to stop
Every project starts from a list — a handful of screens, a calculation, an integration. These are the ones maintenance and reliability teams bring us most.
Vibration and condition monitoring
Wireless vibration and temperature sensors on motors, pumps, fans, gearboxes and compressors, with trends per machine so a slow change is visible long before it becomes a breakdown.
  • Vibration velocity and acceleration
  • Bearing and motor temperature
  • Trends and limits per machine
Condition-based maintenance
Maintenance triggered by what the machine is doing — runtime, cycles, starts, current — instead of the calendar, so service happens when it's needed and not just because a date came round.
  • Runtime and cycle counters
  • Limits per asset class
  • Service due by condition
Anomaly detection and failure models
Baselines learned per machine flag behaviour that doesn't match its normal pattern. Your own models, or ones we build with you, run as Python functions on the platform, next to the data.
  • Per-machine baselines
  • Anomaly scores in the app
  • Models you own and can retrain
CMMS and work-order integration
An alert is only useful if it becomes work. Findings open or update work orders in your CMMS or ERP, and the history of what was done flows back to the machine's record.
  • Work orders from alerts
  • Asset IDs matched to your CMMS
  • Repairs logged against the data
Mobile apps for maintenance technicians
Branded iOS and Android apps for the people on the floor — built as a customisation of an existing app, so login, navigation and push alerts are reused, not rebuilt.
  • Machine health by area
  • Push alerts and acknowledgements
  • Machine history on site
Industrial AI across your maintenance data
Agents that keep an eye on every machine, write the morning health summary and answer questions like “which pumps are trending toward an alarm this week?” through Channels like WhatsApp.
  • Morning machine health summaries
  • Questions answered from live data
  • Actions through Connectors
Connectivity
Connect every machine you need to watch
Condition data comes from new sensors, the controllers already on the machine and the systems your maintenance team works in. We work with what your plant already has, or specify what it needs. Hardware is specified, not supplied.
SENSORS
Vibration and temperature
Battery-powered wireless sensors mounted on the machine, over LoRaWAN or a local gateway, with no cabling to the panel.
CONTROLLERS
PLCs and SCADA
Current, pressure, runtime and machine states already in the PLC, read through an edge gateway over Modbus or MQTT.
HISTORY
Data you already have
Historian or SCADA exports loaded by API, so baselines can start from months of past operation instead of from zero.
SYSTEMS
CMMS and ERP
Your maintenance and asset systems, connected by API or webhook and scoped as their own work package.
Connectivity:LoRaWANModbus via gatewayMQTTHTTP / RESTLTE-M / NB-IoTWebhooks
You own it. We run it.
Completely custom, without a maintenance backlog
A platform you build yourself is worth the most on the day it ships. After that, someone owns its uptime, its security patches and every dependency in it — permanently.
Here, everything above the line is yours: the data model, the screens, the brand. Everything below it is ours to run, under support, and it keeps improving underneath you without landing on your roadmap.
Where a custom application is the deliverable, the code is written as work for hire. You own the repository and have access to it throughout the build, not at the end.
How an engagement runs
Five stages, and the number gets tighter at every one
Nobody can price a conversation accurately. So we tell you how wide the estimate is at each stage, and narrow it by doing work rather than by guessing harder.
Qualification
A short call to capture scope and sizing, and to put an indicative range on the work.
±100%
Specification
Your requirements document — or a fixed-fee, timeboxed discovery that produces one.
±50%
Estimation
Every requirement mapped to a work package, each one sized. A range we can defend line by line.
±50%
Prototype
Something you can use on the real platform before the build is committed. Then re-estimated.
±25%
Build
Agreed scope, stated exclusions, delivered in reviewable increments with monthly effort reporting.
Fixed scope
Discovery, when you need one, is a fixed fee credited in full against the project that follows. Build phases run under a not-to-exceed ceiling you set: work stops for your approval at the ceiling rather than running past it.
On the role of AI
AI compresses the build. Engineers still own the quality.
It would be easy to overclaim here, so plainly: AI-assisted development compresses the build step, which is the part that used to dominate a quote.
It does not compress the senior specification in front of it, or the code review and QA after it. Those are why the result is maintainable, they are done by engineers, and they sit inside the same rate.
Spec
Build — AI-compressed
Review
QA
15%45%15%25%
Typical effort split of a custom build. The cyan block is where the time goes away; the rest is the human quality floor.
In the field
What this looks like in practice
One condition-monitoring deployment running on the platform today, and one platform build by our team.
Water utility · pump condition
A city's water and wastewater stations, monitored remotely
Interagua runs the potable water and sewer systems of Guayaquil, Ecuador's largest city. Its stations are monitored on the Ubidots platform, with alerts when a pump draws too much current, stays offline too long or a station loses communication.
170+stations
15%lower energy costs
18%fewer on-site inspections
Paper-based processes were eliminated along the way. Operators get a single-screen view of station health, with drill-down into each pump's performance and history.
Designed and deployed by Nextergy, an engineering firm and Ubidots partner, on the Ubidots platform; published as a case study on the Ubidots blog. Not a build by our development team.
Equipment manufacturer · white-label platform
An indoor air quality manufacturer building its own platform
They arrived with a finished requirements document and one real question: not "can you build this", but "how much of this do we have to build at all?"
220requirements classified
89.5%deliverable on the platform
~25work packages
145 requirements ship through configuration and 52 through the extension layer. A working prototype was built on the real platform, not in a design tool, and became a delivery asset in its own right.
Enterprise white-label licence closed August 2026 · delivery under way
FAQ
Questions maintenance teams ask first
What is predictive maintenance?
Predictive maintenance is servicing a machine based on evidence that it is starting to fail — rising vibration, a hotter bearing, a motor drawing more current for the same work — instead of on a fixed calendar or after it breaks. Custom software fits it to your machines, your failure modes and the way your maintenance team plans work.
What's the difference between preventive, condition-based and predictive maintenance?
Preventive maintenance follows the calendar or the hour meter. Condition-based maintenance acts when a measured value crosses a limit, like vibration above an alarm level. Predictive maintenance looks at the trend and the pattern to estimate when that limit will be reached. Most programs use all three, and the software should support each.
Why is building on Ubidots faster than building from scratch?
Because the work starts at your data model and your interface, not at an empty repository. Ingestion, time-series storage, authentication, roles, alerting and reporting already exist and are in production. AI-assisted development then compresses the build step itself, while specification, code review and QA stay with senior engineers.
Do we need historical failure data to start?
Not to start. Condition thresholds and per-machine baselines work from the first readings, once a machine has run normally for a while. Models that estimate remaining life need a history of failures to learn from, so they come later, and we'll tell you honestly when your data is ready for them.
Which sensors do we need?
It depends on the failure modes. Wireless vibration and temperature sensors cover most rotating equipment — motors, pumps, fans, gearboxes and compressors — and current, pressure or runtime often come from the PLC already on the machine. We specify the sensors per asset; we don't supply them.
Who maintains the software after it is delivered?
The infrastructure underneath your application — ingestion, storage, orchestration, security, availability and upgrades — is run and maintained by Ubidots under your platform subscription. You own the application layer. Changes to it after delivery are scoped as new work, the same way the original build was.
Do we own the code?
On engagements where a custom application is the deliverable, the code is written as work for hire: you own the repository and the source, with access throughout the build rather than at the end. The platform underneath stays Ubidots'.
How much does custom predictive maintenance software cost?
It depends on scope, and an honest first answer is a range rather than a number. We give that range on the first call, then narrow it at each stage: specification, work-package estimate, and a prototype you can use before the full build is committed. Discovery, when you need one, is a fixed fee credited against the project.
Do we need a Ubidots subscription?
Yes. The application runs on the Ubidots platform, and the subscription is scoped and quoted separately from the development work. Development is not part of a subscription, and a subscription is not part of a development engagement.
Start with one message
Tell us which machines you can't afford to lose
Tell us what you need. We'll get back to you to work out whether there's a project here, and put a range on it that's honest about how wide it still is.
Get in Touch
Get in Touch
Get the best of our product and team
Main IoT verticals (select up to 3)
