Ubidots
Smart agriculture software development
Custom smart agriculture software, from soil to harvest
You own the application; we keep everything underneath it running. We build the soil, irrigation and climate monitoring your growers and agronomists act on — for fields, greenhouses and barns — on a platform already in production.
Why it is faster
A development shop starts with an empty repository. We start with a platform in production.
Most of a smart agriculture application has nothing to do with agriculture. It is ingestion, storage, logins and alerting — and whoever builds it has to maintain it forever.
Building from scratch You pay for all of it
Before anyone builds the irrigation view your growers asked for, a team builds — and then maintains — the whole stack underneath it.
Building on Ubidots You pay for the top
The work begins at your data model and your interface, because everything below that line already exists and is under support.
Reporting and alerting already running
Authentication, users and roles already running
Time-series storage already running
Device ingestion and protocols already running
Security, uptime and upgrades our job
What we build for agriculture
Custom software for every field, greenhouse and barn
Every project starts from a list — a handful of screens, a calculation, an integration. These are the ones growers and agtech companies bring us most.
Soil moisture and irrigation monitoring
Soil moisture at several depths next to what the irrigation system actually did, so growers water by what the root zone needs rather than by the calendar.
  • Soil moisture at several depths
  • Irrigation runtime and water used
  • Pump and valve status
Greenhouse climate monitoring
Temperature, humidity, CO₂ and light per zone, with derived values like vapour pressure deficit calculated from the readings and alerts before conditions favour disease.
  • Climate per zone
  • Vapour pressure deficit from live readings
  • Alerts on heaters, vents and fans
Weather stations and field conditions
On-farm weather stations reporting rain, wind, solar radiation and temperature, turned into the numbers growers plan with: frost risk, growing degree days and spray windows.
  • Rain, wind and solar radiation
  • Frost alerts
  • Growing degree days
Livestock and barn monitoring
Climate, ammonia, water and feed in barns, poultry houses and dairies, so a ventilation failure or an empty water line is caught by an alert instead of on the morning round.
  • Barn and poultry house climate
  • Water and feed tank levels
  • Milk tank temperature
Apps and portals for growers and agronomists
Branded iOS and Android apps for field staff, and portals where an agtech company or distributor gives each client farm its own space — built on what the platform already has, not rebuilt.
  • One space per farm or client
  • Your brand on web and mobile
  • Push alerts for field staff
Industrial AI across your farm data
Agents that combine field readings with weather forecasts, write the morning summary per farm and answer questions like “which blocks need irrigation tomorrow?” through Channels like WhatsApp.
  • Morning summaries per farm
  • Questions answered from live data
  • Actions through Connectors
Connectivity
Connect every field, greenhouse and barn
Farms are spread out and rarely have Wi-Fi where the sensors need to be. We work with what your sites already have, or specify what they need. Hardware is specified, not supplied.
LORAWAN
Sensors across the field
Battery-powered soil, weather and level sensors, with one gateway covering several kilometres of open ground.
CELLULAR
Pumps and remote sites
LTE-M, NB-IoT or 4G for pump stations, weather stations and sites where there's coverage but no network.
CONTROLLERS
Irrigation and climate controllers
Irrigation controllers and greenhouse climate computers, through an edge gateway over Modbus or MQTT, or their own API.
SYSTEMS
Forecasts and farm software
Weather forecasts, farm management software or ERP, connected by API or webhook and scoped as its own work package.
Connectivity:LoRaWANLTE-M / NB-IoTMQTTHTTP / RESTModbus via gatewayWebhooks
You own it. We run it.
Completely custom, without a maintenance backlog
A platform you build yourself is worth the most on the day it ships. After that, someone owns its uptime, its security patches and every dependency in it — permanently.
Here, everything above the line is yours: the data model, the screens, the brand. Everything below it is ours to run, under support, and it keeps improving underneath you without landing on your roadmap.
Where a custom application is the deliverable, the code is written as work for hire. You own the repository and have access to it throughout the build, not at the end.
How an engagement runs
Five stages, and the number gets tighter at every one
Nobody can price a conversation accurately. So we tell you how wide the estimate is at each stage, and narrow it by doing work rather than by guessing harder.
Qualification
A short call to capture scope and sizing, and to put an indicative range on the work.
±100%
Specification
Your requirements document — or a fixed-fee, timeboxed discovery that produces one.
±50%
Estimation
Every requirement mapped to a work package, each one sized. A range we can defend line by line.
±50%
Prototype
Something you can use on the real platform before the build is committed. Then re-estimated.
±25%
Build
Agreed scope, stated exclusions, delivered in reviewable increments with monthly effort reporting.
Fixed scope
Discovery, when you need one, is a fixed fee credited in full against the project that follows. Build phases run under a not-to-exceed ceiling you set: work stops for your approval at the ceiling rather than running past it.
On the role of AI
AI compresses the build. Engineers still own the quality.
It would be easy to overclaim here, so plainly: AI-assisted development compresses the build step, which is the part that used to dominate a quote.
It does not compress the senior specification in front of it, or the code review and QA after it. Those are why the result is maintainable, they are done by engineers, and they sit inside the same rate.
Spec
Build — AI-compressed
Review
QA
15%45%15%25%
Typical effort split of a custom build. The cyan block is where the time goes away; the rest is the human quality floor.
In the field
What this looks like in practice
One precision-farming deployment running on the platform, and one connected-product build by our team.
Regenerative agriculture · Bungoma, Kenya
Soil data for farmers where the internet barely reaches
One Planet Education Network and the Mabanga Agriculture Training Center run precision-farming test sites with local farmers in Bungoma, some of Kenya's most fertile land, where internet access is unreliable.
4growing seasons of data
4soil and air readings per site
Battery-powered sensors report temperature, humidity, electrical conductivity and CO₂ over LoRaWAN to the Ubidots platform, where dashboards and alerts guide irrigation and fertilisation and track the no-till and cover-crop practices being tested.
Deployed by One Planet Education Network and its partners on the Ubidots platform; published as a case study on the Ubidots blog. An education and research project, not a build by our development team.
Industrial distributor · connected product
A gas-detection distributor that needed connectivity of its own
Their detectors competed well on sensing and badly on connectivity. After winning a tender, they needed a connected layer in time to deliver it.
5gases decoded per frame
20–30 spublish interval
An Android app turns the phone into the gateway: it pairs over Bluetooth, decodes the manufacturer's binary frame, tracks location and publishes to a central console with a live map and alarm panel. The client owns the source.
Proposals signed August 2026 · dedicated team, sprint demos as acceptance. The app relays detector data; it is not a safety device and does not replace the detector or its alarms.
FAQ
Questions growers and agtech teams ask first
What is smart agriculture?
Smart agriculture, or smart farming, is using sensors and connected equipment to measure what is happening in fields, greenhouses and barns — soil moisture, weather, climate, water and feed — and acting on it while it still matters, instead of on routine or instinct. Custom software fits it to your crops, your sites and the decisions your growers and agronomists make.
Why is building on Ubidots faster than building from scratch?
Because the work starts at your data model and your interface, not at an empty repository. Ingestion, time-series storage, authentication, roles, alerting and reporting already exist and are in production. AI-assisted development then compresses the build step itself, while specification, code review and QA stay with senior engineers.
How do sensors connect in fields with no Wi-Fi?
Mostly over LoRaWAN, where one gateway covers several kilometres of open field and battery-powered sensors last for years, or over cellular (LTE-M, NB-IoT or 4G) where there is coverage. Greenhouses and barns often have a local network the gateway can use. We specify the hardware for each site; we don't supply it.
Does it replace our farm management software?
No. Farm management software keeps the records — plantings, inputs, labour, accounts. This is the live layer: what the soil, the weather and the equipment are doing right now. The two can be connected by API so field data reaches your records without anyone typing it in, scoped as its own work package.
Can an agtech company or distributor offer it to its own clients?
Yes. Each farm or client gets its own organisation, users and roles, and the application carries your brand on the web and on mobile. Your team sees every client; each client sees only its own fields and sites.
Who maintains the software after it is delivered?
The infrastructure underneath your application — ingestion, storage, orchestration, security, availability and upgrades — is run and maintained by Ubidots under your platform subscription. You own the application layer. Changes to it after delivery are scoped as new work, the same way the original build was.
Do we own the code?
On engagements where a custom application is the deliverable, the code is written as work for hire: you own the repository and the source, with access throughout the build rather than at the end. The platform underneath stays Ubidots'.
How much does custom smart agriculture software cost?
It depends on scope, and an honest first answer is a range rather than a number. We give that range on the first call, then narrow it at each stage: specification, work-package estimate, and a prototype you can use before the full build is committed. Discovery, when you need one, is a fixed fee credited against the project.
Do we need a Ubidots subscription?
Yes. The application runs on the Ubidots platform, and the subscription is scoped and quoted separately from the development work. Development is not part of a subscription, and a subscription is not part of a development engagement.
Start with one message
Tell us what you grow, and what you need to know about it
Tell us what you need. We'll get back to you to work out whether there's a project here, and put a range on it that's honest about how wide it still is.
Get in Touch
Get in Touch
Get the best of our product and team
Main IoT verticals (select up to 3)
