Ubidots
Energy monitoring software development
Custom energy monitoring software, from meter to margin
You own the application; we keep everything underneath it running. We build the consumption, demand and cost views your teams act on — for production lines, utilities and solar sites — on a platform already in production.
Why it is faster
A development shop starts with an empty repository. We start with a platform in production.
Most of an energy application has nothing to do with energy. It is ingestion, storage, logins, alerting and the reports finance asks for — and whoever builds it has to maintain it forever.
Building from scratch You pay for all of it
Before anyone builds the cost-per-line report you asked for, a team builds — and then maintains — the whole stack underneath it.
Building on Ubidots You pay for the top
The work begins at your data model and your interface, because everything below that line already exists and is under support.
Reporting and alerting already running
Authentication, users and roles already running
Time-series storage already running
Device ingestion and protocols already running
Security, uptime and upgrades our job
What we build for energy
Custom software for every meter, line and site
Every project starts from a list — a handful of screens, a calculation, an integration. These are the ones energy and operations teams bring us most.
Electrical submetering and cost allocation
Meters on each line, area or process, so consumption and cost land where they belong instead of in one number on the monthly bill.
  • kWh and cost per line or cost centre
  • Energy per unit produced
  • Monthly reports per site
Power monitoring systems
Three-phase power, demand and power quality from the meters and analysers in your panels, with alerts before a demand peak sets next month's charge.
  • Voltage, current and power factor
  • Demand peak alerts
  • Power quality events, where meters report them
Solar and renewable plant monitoring
Inverters, strings and trackers compared against what they should be producing, so an underperforming string shows up the same day, not in the monthly yield report.
  • Expected vs actual production
  • String and inverter underperformance
  • Daily production reports
Compressed air, gas and water
Energy isn't only electricity. Compressors, boilers and process water are metered alongside it, so a leak or an idle machine running overnight shows up as cost.
  • Compressed air leak detection
  • Gas and water submetering
  • Consumption outside production hours
Energy dashboards and apps for managers
Energy and cost views for plant managers and finance, on the web or as branded iOS and Android apps, built on what the platform already has, so login, roles and alerts are reused, not rebuilt.
  • Budget vs actual per site
  • Shift and line comparisons
  • Scheduled reports by email
Industrial AI across your energy data
Agents that keep an eye on every meter, flag consumption that doesn't match production and answer questions like “which line used the most energy per unit this week?” through Channels like WhatsApp.
  • Morning energy summaries
  • Questions answered from live data
  • Actions through Connectors
Connectivity
Connect every meter, inverter and system
Energy data sits in panel meters, inverters, controllers and vendor clouds. We work with what your sites already have, or specify what they need. Hardware is specified, not supplied.
METERS
Energy meters and analysers
Panel meters and power analysers already installed report over Modbus through an edge gateway; new ones can be wireless or cellular.
CONTROLLERS
PLCs and SCADA
Equipment states and production counts from PLCs or SCADA, through an edge gateway, so energy can be measured per unit produced.
INVERTERS
Solar and storage
Inverters and vendor monitoring clouds, read by API or from scheduled exports, so every site lands in one place.
SYSTEMS
Your other systems
ERP, production or billing software, connected by API or webhook and scoped as its own work package.
Connectivity:Modbus via gatewayMQTTHTTP / RESTLoRaWANLTE-M / NB-IoTWebhooks
You own it. We run it.
Completely custom, without a maintenance backlog
A platform you build yourself is worth the most on the day it ships. After that, someone owns its uptime, its security patches and every dependency in it — permanently.
Here, everything above the line is yours: the data model, the screens, the brand. Everything below it is ours to run, under support, and it keeps improving underneath you without landing on your roadmap.
Where a custom application is the deliverable, the code is written as work for hire. You own the repository and have access to it throughout the build, not at the end.
How an engagement runs
Five stages, and the number gets tighter at every one
Nobody can price a conversation accurately. So we tell you how wide the estimate is at each stage, and narrow it by doing work rather than by guessing harder.
Qualification
A short call to capture scope and sizing, and to put an indicative range on the work.
±100%
Specification
Your requirements document — or a fixed-fee, timeboxed discovery that produces one.
±50%
Estimation
Every requirement mapped to a work package, each one sized. A range we can defend line by line.
±50%
Prototype
Something you can use on the real platform before the build is committed. Then re-estimated.
±25%
Build
Agreed scope, stated exclusions, delivered in reviewable increments with monthly effort reporting.
Fixed scope
Discovery, when you need one, is a fixed fee credited in full against the project that follows. Build phases run under a not-to-exceed ceiling you set: work stops for your approval at the ceiling rather than running past it.
On the role of AI
AI compresses the build. Engineers still own the quality.
It would be easy to overclaim here, so plainly: AI-assisted development compresses the build step, which is the part that used to dominate a quote.
It does not compress the senior specification in front of it, or the code review and QA after it. Those are why the result is maintainable, they are done by engineers, and they sit inside the same rate.
Spec
Build — AI-compressed
Review
QA
15%45%15%25%
Typical effort split of a custom build. The cyan block is where the time goes away; the rest is the human quality floor.
In the field
What this looks like in practice
One energy deployment running on the platform today, and one connected-product build by our team.
Sustainability consultancy · plant utilities
Utility costs made visible, machine by machine
Quantify Environmental, a consultancy in Guelph, Ontario, instruments manufacturing, food and beverage, plastics and pharmaceutical plants whose utility bills arrived once a month as a single number, often from analogue meters.
$250K+annual savings identified for clients
3utilities: electricity, water, gas
Non-invasive, battery-powered wireless sensors feed one white-labelled application on the Ubidots platform, where derived variables turn raw readings into consumption per process and shift, from a night shift's water use to six months of trends.
Built by Quantify Environmental, a Ubidots customer, on the Ubidots platform; published as a case study on the Ubidots blog. Not a build by our development team.
Industrial distributor · connected product
A gas-detection distributor that needed connectivity of its own
Their detectors competed well on sensing and badly on connectivity. After winning a tender, they needed a connected layer in time to deliver it.
5gases decoded per frame
20–30 spublish interval
An Android app turns the phone into the gateway: it pairs over Bluetooth, decodes the manufacturer's binary frame, tracks location and publishes to a central console with a live map and alarm panel. The client owns the source.
Proposals signed August 2026 · dedicated team, sprint demos as acceptance. The app relays detector data; it is not a safety device and does not replace the detector or its alarms.
FAQ
Questions energy teams ask first
What is energy monitoring?
Energy monitoring is continuously measuring how much electricity, gas, compressed air or water your equipment uses — and when — from meters, power analysers and inverters, then turning it into consumption, demand and cost per line, area or site. Custom software fits it to your meters, your tariffs and the decisions your team makes with the numbers.
Why is building on Ubidots faster than building from scratch?
Because the work starts at your data model and your interface, not at an empty repository. Ingestion, time-series storage, authentication, roles, alerting and reporting already exist and are in production. AI-assisted development then compresses the build step itself, while specification, code review and QA stay with senior engineers.
Do we need new meters?
Often not. Many plants already have energy meters, power analysers or inverters that speak Modbus, or a vendor cloud with an API; an edge gateway or an API connection reads them. Where nothing is metered yet, we specify the meters and current transformers each panel needs. Hardware is specified, not supplied.
Will it lower our energy bill?
The software shows where, when and on what energy is spent; savings come from acting on that. Results depend on your equipment, tariffs and how your team responds, so we don't promise a percentage. What we can say is what operators on the platform have reported, like the more than $250,000 a year in savings identified in the story below.
Can it calculate cost with our tariffs?
Yes. Time-of-use rates, demand charges and per-site tariffs are part of the data model, so cost is calculated per meter, line or site as the readings arrive, rather than estimated once a month from the bill.
Who maintains the software after it is delivered?
The infrastructure underneath your application — ingestion, storage, orchestration, security, availability and upgrades — is run and maintained by Ubidots under your platform subscription. You own the application layer. Changes to it after delivery are scoped as new work, the same way the original build was.
Do we own the code?
On engagements where a custom application is the deliverable, the code is written as work for hire: you own the repository and the source, with access throughout the build rather than at the end. The platform underneath stays Ubidots'.
How much does custom energy monitoring software cost?
It depends on scope, and an honest first answer is a range rather than a number. We give that range on the first call, then narrow it at each stage: specification, work-package estimate, and a prototype you can use before the full build is committed. Discovery, when you need one, is a fixed fee credited against the project.
Do we need a Ubidots subscription?
Yes. The application runs on the Ubidots platform, and the subscription is scoped and quoted separately from the development work. Development is not part of a subscription, and a subscription is not part of a development engagement.
Start with one message
Tell us what you meter today, and what you need to know
Tell us what you need. We'll get back to you to work out whether there's a project here, and put a range on it that's honest about how wide it still is.
Get in Touch
Get in Touch
Get the best of our product and team
Main IoT verticals (select up to 3)
